Date/Time: Mon, 21 Sep 2026 17:54:31 +0000
Window -> Reset Windows causing exception
View Count: 660
[2022-08-04 14:24:05]
Zorin - Posts: 23
Exact message:
F.US.EPM22[M] 1 Min #2 | Caught an unhandled exception in c_Chart::WindowProc. Message: 32769, wParam: 33567, lParam: 0 | 2022-08-04 10:11:39.406 *
F.US.EPM22[M] 1 Min #2 | Caught an unhandled exception in c_Chart::WindowProc. Message: 32769, wParam: 33567, lParam: 0 | 2022-08-04 10:22:54.788 *
Update to latest version did NOT help
Chartbook attached
attachmentWin_error.Cht - Attached On 2022-08-04 14:21:58 UTC - Size: 16.39 KB - 186 views
[2022-08-04 14:30:43]
Sierra_Chart Engineering - Posts: 24913
We will check this, but it is very doubtful it is reproducible and we think the cause is actually something else that has gone wrong at an earlier point.
Date Time Of Last Edit: 2022-08-04 14:30:54
[2022-08-04 14:41:49]
Zorin - Posts: 23
Reasons why I've raised this issue are
1. Many similar posts on your SupportBoard Forum
2. I personally never had such a problem before
NOTE : Either you CAN or can NOT reproduce this - please let me know
[2022-08-04 15:02:24]
Also Window >> Reset Windows is unrelated to a particular Chartbook.
It is only related to the Sierra4.config file which is in the Sierra Chart installation folder.
This has never been reported before:
No we cannot reproduce the issue.
Date Time Of Last Edit: 2022-08-04 15:03:08
[2022-08-04 15:27:44]
Zorin - Posts: 23
" ... only related to the Sierra4.config ... "
So what is wrong with it?
How can I fix this ?
" .... never been reported before: ... "
Not exactly the 100% match, but similar problems with "unhandled exception in c_Chart::WindowProc"
Unhandled Exception in Chart Window
Private File
