Date/Time: Sun, 16 Mar 2025 00:10:06 +0000
Linked Charts, both centered on last price
View Count: 302
[2022-08-04 13:09:23]
User337568 - Posts: 61
Hi:
I want to have two linked charts centered on the last price.
Is this possible?
Thank you
[2022-08-04 14:21:42]
John - SC Support - Posts: 38678
You can link the Vertical Scale, so both scales will be the same. Refer to the following:
Chart Settings: Chart Linking >> Vertical Scale (Chart >> Chart Settings >> Linking menu)
You would then want to have one of the charts setup to always center on Last price, which is an option for a Constant Range chart. Refer to the following:
Chart Scale and Scale Adjusting: Constant Range Scale Modes >> Re-Center To The Last Price On Every Update
