Date/Time: Sat, 13 Jun 2026 07:54:18 +0000
GetNumLinesUntilFutureIntersection() Example
View Count: 558
| [2022-08-03 21:27:15] |
| QnReally - Posts: 188 |
Can you please do an example of using GetNumLinesUntilFutureIntersection()? I believe there is a bug in how it reports the number of lines when counting the lines from scsf_ExtendBarGapUntilFutureIntersection(). 1) If I reload a chart with a custom study making a call to GetNumLinesUntilFutureIntersection(), I get increasing number of lines each time I reload my chart. If I stop reloading, it keeps returning the last returned inflated number of lines. 2) Now, if I add any other study to the chart or remove a study from the chart, the number of lines returned by GetNumLinesUntilFutureIntersection() resets back to the correct number! I have no idea how or why this resets the number of lines but the reload/recalculate doesn't. Please see GetNumLinesUntilFutureIntersection() reports increasing numbers on recalculate if you want to reproduce the issue. Thanks. |
| [2022-08-03 21:38:30] |
To be more precise, 1) reload / recalculate (Insert key) increases the lines 2) if I open the Chart Studies (F6) for the chart and then press OK or Apply, the number of lines resets to the correct number. |
