Date/Time: Mon, 17 Mar 2025 09:49:00 +0000
Rithim data
View Count: 366
[2022-08-03 19:54:43] |
User433900 - Posts: 2 |
If I buy Rithimc data from AMP how shall I set the service on Sierra Charts? - in order for the charts to work? Please advice. |
[2022-08-03 21:16:51] |
John - SC Support - Posts: 38678 |
You will need to set your service to Rithmic. Refer to the Setup Instructions at the following link: Rithmic Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
