Date/Time: Sun, 16 Mar 2025 00:05:14 +0000
Trade Activity Log - Column customization
View Count: 623
[2022-08-03 19:01:17]
User358827 - Posts: 21
I am using the trade activity log and filtering on fills. I am then saving the trade log as a TXT file and opening in Excel. My question is whether there is a way to customize/reduce the amount of columns in the trade log prior to saving and importing to Excel. I am using the hide column function in Excel to reduce columns but would like to reduce the columns in the trade log prior to export if possible.
[2022-08-03 19:42:05]
Tony - Posts: 554
Not sure if that can be done, if not, you can always move columns around by click on the first row (title row) of the column you want to move and drag, so those columns will be stay on the left side of the table.
[2022-08-03 20:40:50]
Thanks. I moved the columns and that works fine for what I need.
[2022-08-03 22:02:27]
John - SC Support - Posts: 38678
There is not a way to limit the columns that are displayed, and hence exported, for the Trade Activity Log.
