Date/Time: Sun, 16 Mar 2025 00:02:51 +0000
Order Fills on Tick Charts
View Count: 336
[2022-08-03 14:38:42] |
RdUbz - Posts: 15 |
Hi, I am running version 2411 of Sierra Chart and when I enable show order fills under Trade > Show Order Fills, I am noticing that the lines and triangles showing the entries/exits are completely off (see screenshot). I have my chart set to 'Range Per Bar - Standard (in ticks)'. Not matter what size I use (I currently have it set to 1 tick) the issue persists. Time based charts seem ok. I have removed all studies from the chart and the problem persists.
[2022-08-03 16:31:34] |
Sierra_Chart Engineering - Posts: 18794 |
Refer to: Chart Trading and the Chart DOM: Misaligned Order Fill Markers on Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
