Date/Time: Sun, 16 Mar 2025 00:10:06 +0000
Highlight DOM Rows on Hover - Pointer vs. Hand/Crosshairs
View Count: 480
[2022-08-03 14:28:41] |
RdUbz - Posts: 15 |
Hi Support, If I have the Hand or Cross hairs enabled under Tools, when I hover over the buy or sell column on the chart DOM, only that row within the buy or sell column will become highlighted (see screenshot1). However, if I enable the pointer tool, when I hover over the buy or sell column, the entire row, all the way to the price column becomes highlighted (see screenshot2). I do like this feature and it would be cool to have it available for all tool types when hovering over the buy/sell column in the chart DOM.
[2022-08-03 18:42:09] |
John - SC Support - Posts: 38678 |
Actually, what this is related to is the Crosshairs. When the crosshairs are displayed, you do not get the selection across the DOM to include the Price. It is not related to any particular tool itself. We have set this as a Feature Request. We do not know when we will be able to get to any particular request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-03 20:32:19] |
RdUbz - Posts: 15 |
Hi John, yes. When the crosshairs are enabled, the selection across the DOM is not visible. Thank you for the update and I look forward to seeing this at some point in the future!
