Date/Time: Sun, 16 Mar 2025 00:07:39 +0000
Shortcut to move multiple stops/target all together
View Count: 957
[2022-08-03 14:12:31]
AzharBasri - Posts: 28
I have initiated say three separate one contract trades and I have moved them to a same price using move target/attached stops to price. Then, I want to move them together using target/stop order tick up/down shortcut, but it only move 1 order only. Is there any way that all 3 orders can be moved using shortcut?
[2022-08-03 16:23:10]
User900285 - Posts: 98
Yes just use the same function you used the first time to consolidate those 3 orders to the new price. Do it another time but at your new price.
The move tick up/tick down shortcuts will not move all of the orders, they only move the closest order one tick up or down. If multiple orders are at the same price it will only move one of them. They are 3 completely separate orders and each one has it's own unique order ID.
Look at this video at the timestamp 18:54 to see some examples for implementing the Move Attached Stops/Targets to Price feature:
https://videos.sierrachart.com/SierraChart_Trading_Interface.mp4
Date Time Of Last Edit: 2022-08-03 16:24:34
[2022-08-03 19:09:04]
John - SC Support - Posts: 38678
If you use the Scale In option, then the attached orders will be a single order and will move as you want them to. Refer to the following:
Attached Orders: Scaling In
