Date/Time: Sun, 16 Mar 2025 00:05:13 +0000
CQG 10 micro emini limit
View Count: 314
[2022-08-03 13:30:52]
User181801 - Posts: 42
Is there a way to disable the limitation that CQG places on 10 micro contracts?
Thanks in advance for your help
[2022-08-03 18:21:45]
John - SC Support - Posts: 38678
If this is a CQG limitation, then there is nothing we can do. Check with your broker to see if they can help you with this.
