Date/Time: Thu, 19 Sep 2024 17:10:50 +0000
No charts show unless maximized...only blue title bar shows when not maximized
View Count: 1043
[2014-05-09 12:53:37] |
User33552 - Posts: 23 |
Running charts in XP. Worked fine until this a.m. Have restarted machine and restarted charts. Unless "maximized" only the top blue line of AT shows. No charts show below it. Could not upload because I don't have the tools showing, so I can only upload screenshots |
The charts are not showing unless in.doc - Attached On 2014-05-09 12:52:56 UTC - Size: 106 KB - 361 views |
[2014-05-09 16:35:26] |
When the main window of Sierra Chart / AT Charts is not maximized, you should be able to move your pointer to the bottom edge of the window and then it will change to a pointer with a small up and down arrow. At that time left click on it and drag down. Let us know if you need more help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
