Date/Time: Sun, 16 Mar 2025 00:07:38 +0000
stucked on hystorical download complete on NQU22
View Count: 339
[2022-08-03 10:33:03] |
greyhaze - Posts: 3 |
Hi i'm using a chartbook in Sierra with different instruments without problems i'm using denali feed cme bundle,but he crash and stucked on hystorical download when try to swith to NQU22,also for 30 minutes any help pls
Date Time Of Last Edit: 2022-08-03 11:34:10
[2022-08-03 16:40:16] |
Sierra_Chart Engineering - Posts: 18794 |
Close all of the Chartbooks that you have open with File >> Close All Chartbooks. Delete that Intraday data file by following these instructions: Chart Data and Chart Data Files: Deleting a Chart Data File Open a new chart for that particular symbol and see if there is an issue. The problem could be with one or more of the charts in the Chartbook due to particular studies. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
