Date/Time: Fri, 21 Mar 2025 08:13:03 +0000
Write Bar and Study data to file with study overlay
View Count: 1231
[2022-08-03 10:03:31] |
antayawat - Posts: 3 |
Hello, I am exporting the data of 1800ticks chart with some study calculation made on 1tick chart as overlay study. Sometimes I found that 1tick chart is old values (a few previous bar on 1ticks chart). I suspect the calculation is not finished for current bar on 1tick chart. Is there a setting or programming I can do so the export will not be done unless the overlay study calculation has finished? |
[2022-08-03 18:10:43] |
John - SC Support - Posts: 38835 |
Refer to the following that may help you. General Settings Window: Use Controlled Order Chart Updating (Global Settings >> General Settings >> Charts >> Charts) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-05 18:46:58] |
Thanks. Just want to say it works as you suggested.
