Date/Time: Tue, 22 Sep 2026 07:15:55 +0000
raccourci
View Count: 682
| [2022-08-03 08:22:40] |
| User914407 - Posts: 65 |
Bonjour, Est-il possible d'enlever "Clear current traded bid/ask volume above" et "Clear current traded bid/ask volume below" du clic droit dans le DOM ? Et plus généralement d'ennlever ou ajouter ce qu'on veut ? Merci |
| [2022-08-03 16:35:22] |
| John - SC Support - Posts: 47955 |
From Google Translate: Hello,
Is it possible to remove "Clear current traded bid/ask volume above" and "Clear current traded bid/ask volume below" from the right click in the DOM? And more generally to remove or add what you want? Thanks There are no options to clear specific Bid/Ask volume. Only the option to clear all of the data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-08-03 16:39:00] |
Ma question était d'enlever "Effacer le volume actuel d'offre/demande échangé ci-dessus" du mebu qui apparaît quand on clique droit avec la souris ...
| [2022-08-03 19:27:39] |
From Google Translate: My question was to remove "Clear current bid/ask volume traded above" from the mebu that appears when right mouse clicked... Sorry for the misunderstanding. Yes, you can remove this from the right-click menu. You will need to go to Global Settings >> Customize Chart Shortcut Menu and find it on the list on the right to remove it. Refer to the information here: Global Settings Menu: Customize Chart Shortcut Menu (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-08-04 13:57:35] |
Bonjour, Je parle du menu accessible en clic droit dans le DOM Merci |
| [2022-08-04 14:32:58] |
I'm talking about the right-click menu in the DOM Thanks Sorry, but there is not a way to remove those items from that context menu. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
