Date/Time: Sun, 16 Mar 2025 00:07:38 +0000
new scid files
View Count: 594
[2022-08-03 06:17:19] |
Rnn - Posts: 56 |
hello, i c that there r new scid files since the new versions - for example ESH22_FUT_CME is it safe to delete the older scid files ? for example ESH22 | ESZ19 etc. and also if i want to load data from older files that i have, do i need to keep the older scid files or if theres a request for older data the new type of scid will b re-downloaded anyway? Date Time Of Last Edit: 2022-08-03 14:27:52
[2022-08-03 16:20:05] |
John - SC Support - Posts: 38678 |
As long as you are getting data from our Denali Exchange Data Feed, then you can delete the .scid files you want and if you have a need for that data, then the data will be redownloaded. Refer to the information at the following link for how to find the symbols that are not in use and then delete the appropriate files: Chart Data and Chart Data Files: Cleaning Up Old and Unused Symbols for Efficiency For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-03 19:12:13] |
Sierra_Chart Engineering - Posts: 18794 |
Yes will this will be fine: is it safe to delete the older scid files ? for example ESH22 | ESZ19 etc.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-08-03 19:12:19
