Date/Time: Sun, 16 Mar 2025 00:10:05 +0000
Editing exit price
View Count: 412
[2022-08-03 01:01:04] |
User879924 - Posts: 50 |
I was using my sim account and some orders filled whilst the computer was in sleep mode. I am aware that this is a limitation. Is it possible to go back and manually edit the exit price so that the trade activity and statistics reflect where the trade would have filled had my computer not been in sleep mode? Thanks |
[2022-08-03 13:57:36] |
Sierra_Chart Engineering - Posts: 18794 |
Yes. Refer to: Trade Activity Log: Trade Activity Data Editing Menu Commands (Trade >> Trade Activity Log) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-03 18:27:35] |
John - SC Support - Posts: 38678 |
You may want to look into using our Simulated Futures Trading Service, which stores trades on our server, acting more like the real exchange, so you would not have this issue. Refer to the following: Simulated Futures Trading Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
