Date/Time: Sun, 16 Mar 2025 08:26:28 +0000
Loss Liquidator
View Count: 562
[2022-08-02 19:08:29]
User525384 - Posts: 37
Hi, I currently use Advantage as my FCM and they have made changes as to how they administer the auto liquidation threshold. I used to be able to use a specific dollar amount and the tool functioned properly. The new changes that they have made are as a percent of account size and it is anywhere from 50-60% of account size (possibly 80%). This makes the functionality of the tool obsolete. What are my options if I want to use a specific dollar amount rather than a percent of account size? Can this tool be administered by me and function the same way, by resetting for the next trading session 18:00:00 EST? Please advise. I would like to set the amount and if it triggers the auto liquidation then a reset occurs at the commencement of the next session (18:00:00 EST).
[2022-08-04 07:14:07]
Sierra_Chart Engineering - Posts: 18797
We plan on adding new settings for this for Teton order routing which can be controlled by the user.
[2022-08-04 09:56:15]
Thanks. I would like to ask if a total amount of contracts for a predefined session (18:00:00-17:00:00 next day) can be added as a feature. This is a very helpful risk control parameter to avoid overtrading. I would be willing to help in the cost of development of this tool and some features in order to get the project into production as soon as possible. Please advise.
[2022-08-08 14:17:44]
No, this particular functionality is not planned. We will see if it is not difficult to add.
Date Time Of Last Edit: 2022-08-08 14:18:35
[2022-08-12 16:48:48]
Do you have any timeline for when a decision will be made?
(Thanks. I would like to ask if a total amount of contracts for a predefined session (18:00:00-17:00:00 next day) can be added as a feature. This is a very helpful risk control parameter to avoid overtrading. I would be willing to help in the cost of development of this tool and some features in order to get the project into production as soon as possible. Please advise.)
