Date/Time: Sun, 16 Mar 2025 00:02:54 +0000
Contract not allowed but Ironbeam says it is cleared
View Count: 430
[2022-08-02 16:44:29] |
greenlumber - Posts: 6 |
´Morning, I´m trying to get ZC (corn - cbot) cleared to trade, I´ve contacted Ironbeam who says I´m cleared for it, but I keep getting a message on SC saying the order is rejected by Teton due to symbol not allowed by Master account firm. I´ve contacted Ironbeam again who said I was cleared and should contact Sierra to see what was going on. Can you help me out? Thanks, |
[2022-08-02 17:00:29] |
Sierra_Chart Engineering - Posts: 18794 |
Most likely you are not using the correct symbol. The symbol needs to end with CME. Select Edit >> Translate Symbols to Current Service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-08-02 17:00:36
[2022-08-02 17:58:56] |
No, I have ZCZ22_FUT_CME on the scren, I´ve been following the contract with no issues.
[2022-08-02 18:16:34] |
We will follow up with Ironbeam.
[2022-08-03 12:36:22] |
It started to work today! Thank you.
[2022-08-03 13:07:44] |
Yes they told us they added it.
