Date/Time: Mon, 06 Jul 2026 23:41:08 +0000
Current Price Line Sync
View Count: 770
[2022-08-02 07:24:07]
Mustang77 - Posts: 122
Hi
lately the current price line study does not sync with current price, meaning if ES price is 4091 the current price line will show 4120, even though the displacement in subgraph is set to 0
See photos attached
As you can see in one of the photos, the price is the white label and the price line is way above it
Whats the reson for this? and what is the solution? this is happening quite often
imageF.US.EPU22 [CB][M] 60 Min #10 2022-08-02 09_19_29.422.png / V - Attached On 2022-08-02 07:23:46 UTC - Size: 90.39 KB - 231 views
imageScreenshot 2022-08-02 092133.jpg / V - Attached On 2022-08-02 07:24:00 UTC - Size: 216.96 KB - 217 views
[2022-08-02 08:10:56]
What are the Input settings you have for that particular study? We need to know all of them.
Date Time Of Last Edit: 2022-08-02 08:11:06
[2022-08-04 08:00:21]
Hi
see photo attached of the input settings.
Note: i have noticed that this problem happens on charts where the evening session is disabled ( Chart / use evening session = unticked )
on charts with evening session enabled this problem does not happen.
so basically it seems that the current price line will only work if there is a profile or candles during the evening session.
Any solution to this?
thanks
imageScreenshot 2022-08-04 095949.jpg / V - Attached On 2022-08-04 08:00:14 UTC - Size: 185.63 KB - 181 views
[2022-08-04 09:06:40]
Sierra_Chart Engineering - Posts: 24190
Yes we do recognize the issue is related to Session Times.
Set this Input to Yes
Use Last Trade Price from Current Quote Data.
