Date/Time: Mon, 17 Mar 2025 09:47:47 +0000
grafico de tick (tick chart)
View Count: 420
[2022-08-02 02:22:27] |
luciana - Posts: 24 |
Hello I would like to set up a tick chart, which is part of the internals, as they are called, for micro sp 500 with one minute candlesticks. And I also want to add to that, the awesome oscillator studio, with a 1-minute timeframe as well. They could advise me. Thank you (translated from) Hola Quisiera establecer un grafico de tick, que es parte de los internals, como se llaman, para micro sp 500 con velas japonesas de un minuto. Y también quiero agregar a ello, el estudio awesome oscillator, con temporalidad de 1 minuto también. Podrían asesorarme. Gracias |
[2022-08-02 18:55:55] |
John - SC Support - Posts: 38678 |
Sorry, but we are not fully understanding what you want to do. If you are looking for the TICK statistic (Up stocks minus Down stocks) for the S&P 500, then this is part of our Market Statistics data. Refer to the information at the following link for how to access this data: Sierra Chart Market Statistics If you are looking for the data from The CME Group for the Micro S&P 500, then you have access to this through your subscription to our Denali Exchange Data Feed. The specific symbol depends on what trading service you are using, so we can not tell you exactly what the symbol is in your case, but you can access the list of symbols by selecting File >> Find Symbol and then looking for the micro S&P 500 within the CME exchange section. Refer to the following for how to use the Find Symbol window: In terms of the Awesome Oscillator, it is a study that we have available, so follow the instructions at the following link to add the study to the chart on which you want it: Chart Studies: Adding/Modifying Chart Studies For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
