Date/Time: Tue, 26 Nov 2024 11:43:59 +0000
[User Discussion] - Vertical Line triggered at defined levels
View Count: 947
[2014-05-09 06:09:11] |
Dom7364 - Posts: 257 |
Would there be a clever way to trigger a vertical line on a bar chart, when a threshold/level is crossed? For example, if we have over 400 contracts on either side, it will either draw a vertical red line or a vertical green line, which will remained and only disappeared once crossed (or even stay on the chart would be good enough!) Thanks |
