Date/Time: Sun, 16 Mar 2025 00:05:13 +0000
[User Discussion] - Issues since update to current verision
View Count: 385
[2022-08-02 00:35:33] |
jerzjorge - Posts: 1 |
I am usable to access my live data feed since I updated my SC. Can someone help me make sure I am using to correct settings ? I CQG and also have and also pay for the Denial feed and package 11. I only trade the ES & MES Also, I how do I get the session time to stay the same. Every time I switch from ES to MES I have to go into chart settings and update it from 16:15:00 to 18:00:00 Can anyone help with this as well ? |
[2022-08-02 08:14:07] |
You need to activate the CME exchange here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Also, I how do I get the session time to stay the same. Every time I switch from ES to MES I have to go into chart settings and update it from 16:15:00 to 18:00:00 Chart Session Times: Session Times Automatically Changing Unexpectedly And: Global Symbol Settings: Setting of Intraday Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
