Date/Time: Sun, 16 Mar 2025 00:00:21 +0000
New access to CME data
View Count: 474
[2022-08-01 15:42:26]
User470516 - Posts: 78
Hello SC Team,
We currently have two Eurex connections and would like to subscribe to CME real time data.
We have a non professional funded account with Interactive Brokers.
Does one subscription (3.5USD/month) enable two separate PCs to simultaneously access CME data at the same time the way it works with Eurex? In case the answer is no, what is the procedure to have two simultaneuous accesses?
Thank you,
Regards
[2022-08-01 16:09:35]
John - SC Support - Posts: 38678
You can have two separate computers accessing the data from the Denali Exchange Data Feed for the CME Group data, just like you are doing for the EUREX data.
The setting for the number of systems applies to all the Denali Exchanges. Therefore, by having selected the option for 2 systems for EUREX data, you have set this for all the exchange options from the Denali Exchange Data Feed. So any new exchanges you activate will automatically be at twice the exchange fee. So there is nothing more you need to do other than setup the data.
For the CME Group data, you will need to follow through these instructions:
