Date/Time: Sun, 16 Mar 2025 00:02:52 +0000
2nd Instance stopped connecting to data today 8-1-22
View Count: 365
[2022-08-01 14:27:24]
John Ryan - Posts: 4
I have been using a 2nd instance for the past 6 months. I am using Denali Data. I am using CQG for routing trade via AMP.
This morning 8:30am EDT after starting SC I opened up a new instance. The 2nd instance will not connect.
I am running SC version 2419 64-bit, which was installed today in response to a SC system message that was directed at the 2nd instance not connecting.
I can send the log from each instance.
The log from the main instance says it is having a problem connecting
"Socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-08-01 09:55:40.031"
[2022-08-01 15:01:05]
I hate Windows. A reboot solved the problem.
