Date/Time: Thu, 28 Nov 2024 15:40:28 +0000
Saving a drawing as custom drawing and control bar button
View Count: 686
[2022-08-01 13:16:08]
User409644 - Posts: 45
Good morning.
I am trying to save a horizontal line, with the same color, text, and wanting it to extend throughout the day. I have not been able to find the instructions to allow me to fist save the parameters of the drawing tool, and then save it to the control bar with my other buttons.
thank you
[2022-08-01 15:06:08]
John - SC Support - Posts: 36350
The documentation you want is at the following link:
Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step
[2023-04-14 12:59:47]
Good morning.
I was successful saving a drawing tool onthe control bar. I am trying to now save the drawing vol profile tool as a button on the control bar for quick drawing, but the problem i am facing is saving the tool with the same settings, for example, having the bars line up on the right side....I am having an issue saving my desired settings so they are the same every time I activate the button to draw.
Any suggestions on how to solve that issue ?
Thank you.
[2023-04-14 16:20:27]
Refer to the following instructions:
Volume By Price Study: Step by Step Instructions to Configure the Draw Volume Profile Tool
