Date/Time: Sun, 16 Mar 2025 00:05:14 +0000
Indicator that shows number of ticks from open of each bar?
View Count: 410
[2022-08-01 04:16:02]
bluejune - Posts: 34
Hi, I have a tick candlestick chart set up. Is there a way to put an indicator for “X” number of ticks away from the open of each bar?
For example, can I put a dashed line that automatically highlights 1 tick from the open of each candle stick bar?
Thank you.
[2022-08-01 13:32:38]
Yes. Refer to:
Using the Basic Arithmetic Studies
