Date/Time: Sun, 16 Mar 2025 00:00:21 +0000
Glitchy data stream
View Count: 420
[2022-08-01 01:16:59] |
User104714 - Posts: 25 |
Hello, for some reason, live data is coming through glitchy. Imagine a poor frames-per-second type of setting...it's not smooth. Candle formation. If there a nanosecond type of update setting, that updates faster, for smooth charts? Thanks.
[2022-08-01 10:07:34] |
Refer to: Prices / Data Falling Behind Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
