Date/Time: Sun, 16 Mar 2025 00:07:40 +0000
2 PC wont work
View Count: 383
[2022-07-31 09:26:48]
User785809 - Posts: 18
I have paid the additional fees to have 2 pc running side by side at the same time but I still get this error can you help
imageSierra 2 PC Error.jpg / V - Attached On 2022-07-31 09:26:35 UTC - Size: 16.47 KB - 119 views
[2022-07-31 15:48:48]
CQG does not allow two connections at the same time. If you are trading the CME Group of markets, you will need to move to the Teton Order Routing service which allows an unlimited number of connections:
