Date/Time: Sun, 16 Mar 2025 00:10:06 +0000
continuous FDAX futures contracts
View Count: 456
[2022-07-30 03:27:41]
shy - Posts: 23
I am trying to set the chart to show continuous data, but fail to do so.
Following the instructions in this page - Continuous Futures Contract Charts: Introduction
I found that the *File >> Connect to Data Feed* doesn't work in my side of the platform.
What sould I do to use a continuous intraday data on the FDAX contract?
Regards,
Shy
[2022-07-30 10:29:58]
If Connect to Data Feed is disabled it means that Sierra Chart is already connected to the data feed.
Follow through the instructions again:
You should not have a problem with Continuous Futures Contract charts.
[2022-07-31 07:42:38]
shy - Posts: 23
I used the procidures you suggested and still have the problem!
[2022-07-31 09:13:10]
Provide an image of the chart after you set it up as a Continuous Futures Contract chart, by following these instructions:
Date Time Of Last Edit: 2022-07-31 09:13:21
[2022-07-31 19:27:54]
shy - Posts: 23
https://www.sierrachart.com/image.php?Image=165929560751.png
can't you just enter unto my account the see what is wrong?
[2022-08-01 07:43:31]
Sierra_Chart Engineering - Posts: 18794
One problem we see that is going to cause issues is the symbol of the chart is not the active futures contract. You are using H23. Change it to FDAXU22.
Also refer to:
Continuous Futures Contract Charts: Displaying Rollover Transition Times and Contract Months
[2022-08-03 20:05:38]
shy - Posts: 23
sorry, but the links you keep sending me DON'T help me solve the problem!
cann't any one connect to my computer and watch things in first hand?
