Date/Time: Mon, 14 Sep 2026 09:01:29 +0000
[Locked] - GDI drawing variables
View Count: 1364
| [2022-07-29 23:21:08] |
| Trader_Rob - Posts: 18 |
I'm trying to do some custom graphing with sc.p_GDIFunction Looking at the example code, it doesn't seem possible to pass in custom values/variables to the draw function, correct? Thank you! |
| [2022-07-30 10:33:26] |
Not directly but you can use persistent variables and set them in the main study function and access them in the drawing function: ACSIL Interface Members - Functions: sc.GetPersistentIntFast() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
