Date/Time: Sat, 15 Mar 2025 16:03:04 +0000
Web manual and DTCProtocol.h have different info about HistoricalPrice.StartDateTime field
View Count: 455
[2022-07-29 15:27:51]
donnicky - Posts: 33
Hello!
If one looks at DTCProtocol.h it says it is t_DateTimeWithMicrosecondsInt/t_DateTime and suggests checking value to determine. But online help says it is t_DateTime only. What value should server put to this field?
image2022-07-29_18-23-44_730cd5ca-9811-4f11-b84e-969ff1f221f3.png / V - Attached On 2022-07-29 15:25:30 UTC - Size: 167.36 KB - 103 views
[2022-07-29 16:08:20]
Sierra Chart actually has the ability to interpret that field either way.
We recommend using:
