Date/Time: Sat, 15 Mar 2025 16:05:23 +0000
Ask Volume Vs Bid Volume Percent
View Count: 767
[2022-07-29 08:30:27] |
User599829 - Posts: 6 |
I have just updated to the latest Sierra Chart version. But now a study that I use each day is no longer reading correctly. The study is the "Numbers Bars Calculated Values" And I am specifically referring to the subgraph called : "Ask Volume Bid Volume Difference Percent" This subgraph was working fine until I downloaded the current version of Sierra. It now just shows the value of "0" for each bar printed. Is this some sort of glitch? I rely on this study every trading day. Thanks |
[2022-07-29 09:42:11] |
No you need to adjust a new input called: Number of Decimal Places for % Values Set it to 2. Refer to: Chart Studies: Adding/Modifying Chart Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
