Date/Time: Fri, 02 Oct 2026 23:03:00 +0000
STUDIES
View Count: 750
[2022-07-28 23:02:50]
User134198 - Posts: 3
I have more studies on my laptop then my desktop. How can I get all the studies on my desktop? It says --SIERRACHARTSTUDIES_64dll is missing possibly
[2022-07-29 09:51:40]
That file should not be missing. If that is missing then install Sierra Chart again into the same folder:
Software Download
For other custom studies, these are contained in DLL files and you just need to copy the DLL files from your desktop computer Data Files Folder to the corresponding folder on your laptop computer:
General Settings Window: Data Files Folder (Global Settings >> General Settings >> Paths >> Files and Folder Paths)
Date Time Of Last Edit: 2022-07-29 09:52:19
