Date/Time: Sun, 16 Mar 2025 00:02:54 +0000
Ironbeam Direct CME Order Routing
View Count: 491
[2022-07-28 22:19:32] |
Martinyan333 - Posts: 27 |
Hello, I've recently joined a fund that lets me connect to Sierra through Rithmic Trader Pro and to get real time futures data I need to have a live funded futures account. I set up an Ironbeam account, funded it, and requested Direct CME order routing from them. Everything on there end is done, I was told I'd either get a call or an email from john and SC but nothing so far. Was hoping someone could get in touch with me so we can get everything done. Thank you in advance |
[2022-07-29 09:33:11] |
First and we want you to do is to go through the setup instructions here starting at step 7: Sierra Chart Teton Futures Order Routing: Setup Instructions See if you are able to connect. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-29 09:33:17
[2022-07-29 16:14:48] |
I am unable to connect to the data feed. I'm getting an error that says "No trade accounts assigned". |
[2022-07-29 19:08:48] |
SC Support - Posts: 1941 |
Spoke to Matthew, we are waiting on Ironbeam to complete the set-up on their side.
