Date/Time: Wed, 23 Apr 2025 03:24:10 +0000
Field to access the available balance for entering new trades?
View Count: 504
[2022-07-28 22:09:13] |
TriStar Trading - Posts: 154 |
Is there a field to access the available balance for entering new trades using n_ACSIL::s_TradeAccountDataFields TradeAccountDataFields; Thanks, Mike
[2022-07-29 09:30:48] |
Yes it is : n_ACSIL.s_TradeAccountDataFields.m_AvailableFundsForNewPositions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-04 18:21:28] |
Fanch - Posts: 19 |
I can't find the documentation for the n_ACSIL::s_TradeAccountDataFields type, and my intellisense is not grokking it either. I am looking to access the Peak balance from my Rithmic account, is that exposed in the structure? Thank you, F |
