Date/Time: Sat, 15 Mar 2025 16:05:22 +0000
bouton
View Count: 428
[2022-07-28 14:08:36]
User914407 - Posts: 49
Bonjour,
Comment créer un bouton "Alert" sur la "Control Bar" pour metrre en palce une alerte et un autre bouton pour annuler l'alerte en cours ?
MErci
[2022-07-28 16:53:23]
John - SC Support - Posts: 38678
From Google Translate:
How to create an "Alert" button on the "Control Bar" to set an alert and another button to cancel the current alert?
Thank you
There is not a built-in way to do this.
The only way that this could be done would be to create a custom study that took care of your alerts, so you could then use a Control Bar button to enable/disable within your study. Refer to the information starting here:
Advanced Custom Study Interface and Language (ACSIL): Introduction
