Date/Time: Sun, 16 Mar 2025 08:28:51 +0000
Target Order Tick Up/ Down not working
View Count: 686
[2022-07-28 12:51:40]
User286186 - Posts: 22
As it is explained in the link below, I would like to assign a keyboard button to the function Target Order Tick Up (and another one for Down).
I am currently using Attached orders with one Target (+30 ticks) and one Stop (-20 ticks).
It should be working but it does not.
Of course, I have Trading Keyboard SHortcut enabled, and all other Keyboard shortcuts I am usign work perfectly fine.
Thank you for your help
Source : Basic Trading and the Trade Window: Trading Keyboard Shortcuts
[2022-07-28 13:59:26]
Do you see any errors in the Window >> Message Log when you use that keyboard shortcut?
[2022-07-28 14:01:42]
No, there is no error in the Message Log.
[2022-07-28 16:47:51]
John - SC Support - Posts: 38678
Keep in mind that there are two different Target Tick Up/Down options, one for Attached Orders and one for Non-Attached Limit Orders. Make sure you are using the correct one.
[2022-07-29 09:45:55]
Let us know if the above information helped you to resolve the issue?
[2022-08-09 10:21:11]
NeXie - Posts: 2
Hello, every options i tryed only moved attached orders. The none attached orders doesn't move.
imageSans titre.png / V - Attached On 2022-08-09 10:20:14 UTC - Size: 9.02 KB - 127 views
[2022-08-09 14:20:47]
The first thing is to ensure that the option for Trade >> Trading Keyboard Shortcuts Enabled is enabled (has a checkmark next to it). If it does not, then the keyboard shortcuts will not work.
Next, the other thing we see is a single letter (U) being used for a shortcut. This is not good practice as there can be a confusion as to whether you want the letter U or the shortcut. It will work most of the time, but there can be times when there will be an issue. You should apply a modifier or two to the letter.
[2022-08-11 17:44:21]
NeXie - Posts: 2
None of what you said worked but i removed the assignment multiple times and it finally worked.
For the owner of this thread it still doesn't work.
