Date/Time: Sun, 16 Mar 2025 06:05:02 +0000
pleasue can you extend my trial
View Count: 435
[2022-07-28 10:18:56]
User653779 - Posts: 1
hello i wasnt able to use my trial of sieera chart so can you please extend my trial for some more days
[2022-07-28 10:45:00]
Your trial has been reset.
[2022-07-29 16:26:41]
User434076 - Posts: 1
hi i signed up for the trial and did not get to use it could i be reset to please would like to give it a go this weekend. thanks
[2022-07-29 17:29:13]
Your account has been activated and the usage time extended if necessary.
If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu.
After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit".
