Date/Time: Sat, 15 Mar 2025 16:03:00 +0000
Get Chart Symbol Description
View Count: 448
[2022-07-28 06:36:21] |
Trader_Rob - Posts: 18 |
How do I access the "description" (not sure what it's actually called) after the symbol name in ACSIL? The ones I'm looking for don't appear in the symbol settings files. I attached an image of the chart window menu for reference. Thanks! |
[2022-07-28 14:14:02] |
This is the function you need to use: ACSIL Interface Members - Functions: sc.GetSymbolDescription() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
