Date/Time: Sat, 15 Mar 2025 16:00:36 +0000
Saving, removing and adding a single chart
View Count: 437
[2022-07-27 21:39:00]
User358827 - Posts: 21
I have created a 30 second chart within my chartbook that I want to use during times of high volatility however I would prefer not to have this chart as part of my chartbook during normal volatility to reduce load on my charting and trading system. Is there a way I can remove the chart, save the chart, and then add it back to my chartbook at a later time? I read through the documentation but it was not clear to me if this could be done.
Thanks for your help.
[2022-07-27 21:52:19]
John - SC Support - Posts: 38678
Just "hide" the chart. Refer to the following:
Window, CB and CW Menus: Hide Window (Window)
[2022-07-27 22:01:48]
Thanks. That's very helpful.
