Date/Time: Sat, 15 Mar 2025 16:03:04 +0000
Chart Trade Dom Columns
View Count: 652
[2022-07-27 19:22:50]
Technical - Posts: 158
I have my DOM set up with "Bid Size/Buy Column" and "Ask Size/Sell Column"
I also have the "Show Volume Bars" set to Auto.
(See enclosed) For some reason, the volume bars expand, contract and expand quickly - without a significant change in the Bid or Ask amounts. What causes this fluctuation and how can I stabilize it?
image2022-07-27 13_48_31-Capture.png / V - Attached On 2022-07-27 19:17:23 UTC - Size: 584.61 KB - 147 views
[2022-07-27 20:31:55]
John - SC Support - Posts: 38678
There can be large orders sitting very far off from what you can see on the screen that are impacting the size of the bars.
[2022-07-27 20:34:57]
Can I filter those?
[2022-07-27 21:15:25]
There is not a way to filter the data in the DOM Columns.
You can, however, limit the number values that are displayed, refer to the information here:
Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu)
