Date/Time: Mon, 21 Apr 2025 18:04:48 +0000
[User Discussion] - Copy trade across two installs
View Count: 1630
[2022-07-27 19:14:07] |
AndrewConroy - Posts: 12 |
Hello, I'm curious if it's possible to request that the trade copier work across multiple installs. This is very helpful when working with two accounts across two brokers. I don't believe the feature to be currently included in the copier. If it is, let me know how to make that work. I'd assume there would show a the accounts from the second install inside the copier settings. Let me know if it's possible. It's a major asset to the platform with how retail traders are currently using the software. Thanks, Andrew |
[2022-07-27 20:30:56] |
John - SC Support - Posts: 39380 |
This is not supported.
[2022-07-27 22:06:19] |
This classic SC response invites me to ask more questions. ;) No worries. I have a solution. |
[2022-08-01 02:08:17] |
User139065 - Posts: 22 |
This developer has what you need to make the magic you are looking for happen. https://www.simplesystemtrading.com/local-trade-copier/ |
[2022-08-01 07:54:41] |
Yes, this functionality documented here does not work across installations of Sierra Chart: Order Allocation to Trade Accounts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-01 09:08:24] |
User538960 - Posts: 29 |
@Andrew: You are not the first one asking for this function to be added. :-) Apparently there have been plenty of requests in that regard. When I asked about it here (Trade Copier for Accounts Connected to Different Trading Services?), I was told that it is already on the "requested features" list. So, it will probably be added in the future; it is just unclear when. By the way: I've tried the SST copier, and I don't like it for a few reasons. However, I certainly don't want to spoil Frederik's business, so give it a try yourself and see what you think. (I for one will wait for a solution offered by SC...just hoping it won't take years. :-) ) Date Time Of Last Edit: 2022-08-01 09:14:54
[2022-08-01 13:24:23] |
Thanks for the info! I'm using the SST study as my work around. Got it working pretty well but I would much rather work with something native to SC, if possible. I'll keep jamming with this for now and keep my eyes peeled for an update. |
[2023-05-11 01:45:26] |
User459170 - Posts: 262 |
Would copying over the trade activity log folder to another installation work for backtesting?
[2024-03-29 03:59:02] |
User644077 - Posts: 5 |
is the functionality available now after two years?
[2024-08-23 14:40:27] |
User936941 - Posts: 28 |
Post #9, Not that I can see. Best bet would be 3rd party. |
[2025-02-21 17:16:26] |
LTSys - Posts: 68 |
Here is a link to a Sierra Chart trade copier... https://lumens.llc/trade_copier_sierrachart.html Date Time Of Last Edit: 2025-02-21 22:23:20
