Date/Time: Sat, 15 Mar 2025 16:03:02 +0000
Color TPO row based on TPO count
View Count: 509
[2022-07-27 18:03:10]
jb2294 - Posts: 14
I am aware that there is a feature in TPO where TPO rows can be colored based on percentage of POC volume.
Similarly, is there a way to color the rows based on TPO count?
[2022-07-27 20:19:29]
John - SC Support - Posts: 38678
First of all, there is not an option to color a TPO row based on Percentage of POC volume. This is a Volume by Price capability.
Second, there is also not a way to color TPOs based on TPO count.
Third, if you are really wanting to color the Volume by Price based on the Percent of POC where the POC is determined by the TPO count, then this can be done. To do this, set the following:
- Add a TPO study to the chart.
- Add a Volume by Price Study to the same chart. By default, the VbP will be set to use the information from the TPOs.
- Set the Volume Bar Calculation Method to Number of Trades. Since the VbP is associated with the TPO, the number of trades is actually the TPO count per price level.
- Set the Bid Volume/Ask Volume Coloring Method to None.
- Set the Color Code Volume Bars Based on Percentage of POC to Yes.
