Date/Time: Sat, 15 Mar 2025 16:10:15 +0000
Scrollbar at drawing tools settings not works
View Count: 360
[2022-07-27 15:57:50] |
User687917 - Posts: 75 |
Hi, In the fibonacci retracement tool and other tools, the scroll bar does not work and I cannot edit some properties of the tool I have asked a couple of users of the platform and they tell me the same thing, it does not let them use the scroll bar. |
[2022-07-27 16:25:59] |
What operating system are you running. We are not observing a problem with this.
[2022-07-27 16:30:26] |
I'm using Manjaro (Linux) and SierraChart v2416 installed throught winetricks
[2022-07-27 16:44:41] |
Ok, we are not going to be able to help with this in the existing Tool Configuration/Properties window but we will be getting started on the new implementation of these Configuration/Properties windows. We will try to start today. These are the risks, of using another operating system other than Windows. There are some things we just cannot help with. But we will indirectly solve it but the soonest would be 2 to 3 weeks. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-27 16:45:37
[2022-07-27 16:48:41] |
Thanks In many years with Linux.. I like it so much. Sierra Chart runs some faster than in windows system If there is some version of Sierra Chart for Linux.. it will be awesome! |
