Date/Time: Wed, 19 Mar 2025 19:13:36 +0000
[Locked] - Detach Chartbook
View Count: 687
[2022-07-27 15:10:14] |
User754379 - Posts: 13 |
Dear Sierrachart Team. i use multi Chartbooks withe multimonitors.. so it would be a great Feature if it will be possible to detach Chartbooks to use it on different Monitors. If it will be possible it would make the handling a littlebit easier and iam more flexible. If you think this could be a good feature for your fantastic software i am looking forward for the next update with this helpfull feature.. BR Joe... |
[2022-07-27 19:06:24] |
John - SC Support - Posts: 38806 |
The only way to do this right now would be to use a Sub-Instance, that way you can have the full software available in multiple monitors. We have also marked this as a Feature Request. Just keep in mind that we can not say when we can get to any particular feature. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-10-24 15:05:56] |
User758499 - Posts: 10 |
Any update on this feature, pretty essential for anyone using multiple monitors seeing as though you can't share drawing between instances
[2022-10-28 20:39:30] |
User90125 - Posts: 715 |
+1
[2022-10-30 20:30:24] |
MandelBro - Posts: 10 |
+1 There are less advanced trading platforms than Sierra which have this essential feature. Date Time Of Last Edit: 2022-10-31 06:22:46
[2022-10-31 08:14:43] |
caxxxxxx - Posts: 12 |
+1
