Date/Time: Sat, 15 Mar 2025 16:10:14 +0000
3 Problems
View Count: 366
[2022-07-27 14:12:51] |
User967541 - Posts: 1 |
Hi Sierra Chart, I have 3 problems: - I switch between two markets with the quoteboard but the markets do not go to their current price by themself = e.g. I switch between CL and GC and I have to scroll down or up to see the current price of the Chart. - can this be automatically? - When I add tools such as lines, rectangles, etc. and close SC (after saving all) the tools will be there after reopening but they are on different price level. - The market profile charts always go back into a cluster when i switch between two markets with the quoteboard but I want the current day chart open and not in a cluster. - is that possible? I hope you can understand me and you can help me. Best wishes Roman |
[2022-07-27 14:37:46] |
1. Refer to: Chart Scale and Scale Adjusting: Chart Bars or Studies Not Completely within View, Not Displayed, or Cut Off. Reset Scales. 2. Make sure the main price graph of the chart is using an Automatic Scale Range. The section linked above explains this. 3. This is hard for us to understand, but we recommend not using the Quote Board to change the symbol of the TPO chart if you are running into a problem like this. Do not use one of these charts. Use another chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
