Date/Time: Wed, 27 Nov 2024 02:28:54 +0000
Trading S&P 500 index options on Sierra chart
View Count: 1913
[2022-07-27 13:24:37] |
Divesh - Posts: 9 |
Hi 1)Could you please advise if I can trade S&P 500 options from Sierra chart? If yes could you please advise how can I Set this up ? I use AMP Futures as my broker. 2)Where can I check the margins for trading S&P 500 options ? 3) If we cannot trade options on Sierra chart then can you please advise where else can we trade options ? Thanks in advance. Divesh. |
[2022-07-27 13:28:21] |
1. Yes you can do this through CQG: CQG Trading Platform Service 2. Not sure. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-27 14:58:00] |
Divesh - Posts: 9 |
Hi Many thanks I will look at the instructions to set this up. 1) Is naked selling of options allowed ? For eg- Shorting only puts and Calls? 2) Do I have to sell a put or a call option along with a Future ? |
[2022-07-27 15:18:25] |
1. Through AMP, the answer is no. 2. Check with your broker on this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-27 15:39:22] |
Divesh - Posts: 9 |
I am going to trade using a separate broker for options as Amp doesnt allow shorting options. 1) So can I please clarify that to trade options through CQG as trading platform service, I first will have to open a broker account with CQG and then follow the steps from your first message ? 2)Other alternative is to find another broker who allows options selling via CQG trading platform ? Can you please suggest some if you are aware of any ? Thanks |
[2022-07-29 19:20:33] |
Sierra_Chart Engineering - Posts: 17190 |
1. You can trade futures options through CQG, Rithmic or Interactive Brokers. All of these services are supported by Sierra Chart. 2. We do not know what brokers support this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-29 19:20:47
