Date/Time: Sat, 15 Mar 2025 16:07:48 +0000
Applying global settings to DOM, and then changing.
View Count: 643
[2022-07-27 11:43:30]
KylieV1618 - Posts: 67
Im pretty sure this feature isn't available (cant find out how to do it).
But if its not, could I make a feature request??
The ability to apply the global settings to a DOM, and then be able to adjust them specifically for that DOM only.
Example...
1. Ive created the perfect layout for my DOMS. But now....I want each DOM to have a different colour for the Price Values Scale.
2. So Id like to be able to "Apply the global settings" (copy them to non-global settings for that DOM), and then be able to adjust the colour of just that one dom.
Right now, unchecking the global, makes the dom appear as the default settings again. Id like to simply be able to clone the global settings to the DOM first, and then adjust.
Is this a possible feature to request??
I know the workaround is to edit a non-global DOM, and then duplicate and change. But it would be nice to be able to just quickly apply/clone the global settings for every new DOM, so that I dont have to do that.
Or maybe another good way to do it, would be to have each setting have its own checkbox that says "Overwrite global" just for that one.
So lets say you have global checked for the settings on a DOM.
Then I would highlight and change "Price Values Scale", and check the checkbox that says "overwrite global for this value" or something along those lines.
The implementation details I guess would be decided by how its progrzammed obviously.
Kylie
Date Time Of Last Edit: 2022-07-27 11:47:03
[2022-07-27 18:58:56]
John - SC Support - Posts: 38678
There is not a way to do what you are asking for at this time.
Therefore, we have made this a feature request. Keep in mind that we do not know when we will be able to get to any particular request.
