Date/Time: Sat, 15 Mar 2025 16:10:14 +0000
problem with Re-Center the DOM
View Count: 405
[2022-07-26 19:11:06] |
User449884 - Posts: 167 |
having issues re-centering the Dom. Everytime i try it brings it somewhere completely irrelevant to current price
[2022-07-26 19:35:38] |
John - SC Support - Posts: 38678 |
One of the things we see is that you have a large value in the "Ticks from Edge" setting, which should not have an impact, given that your Constant Range setting is "Keep Last Bar Within View", but it is having an impact (we will have to look into why). So we first recommend setting that value to 0. The other thing you may want to consider is to use the "Constant Range" type of "Re-Center to the Last Price On Every Update". You will find the information on the Scale Settings on the following page: Chart Scale and Scale Adjusting For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
