Date/Time: Sat, 15 Mar 2025 16:07:47 +0000
Max Connections For Same Device, more than 3
View Count: 1008
[2022-07-26 17:03:28] |
jomanos - Posts: 27 |
In order to avoid getting the below Logon error message that the connection limitation was exceeded, and to avoid re-mapping each symbol settings for the Destination instance (4th Connection) to the DTC Server of the Source instance (1 of the 3 Connections), can I just add full CME top-of-book ($3.50 per month) to my account and access this feed separately with the 4th Connection? I currently pay for the full CME market depth, but will only need top-of-book for the 4th connection. SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 4 | 2022-07-26 15:42:06.969
[2022-07-26 17:28:21] |
John - SC Support - Posts: 38678 |
You can not do what you are suggesting. The exchanges themselves do not matter, you can only have 2 connections on a single computer to the Denali Exchange Data Feed. The only option on a single computer would be to make the 4th installation the same as the 3rd (using DTC Server to connect to one of the other installations). Another option would be to have 2 installations per computer on 2 different computers. You would then need to pay the Exchange fee twice, but it would allow you to get the data to all 4 installations directly. Refer to the information on connections for the Denali data at the following link: Denali Exchange Data Feed: Connections For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
