Date/Time: Sat, 15 Mar 2025 16:07:50 +0000
no security definition has been found for the request
View Count: 681
[2022-07-26 16:18:12] |
JoshuaVrijbergen - Posts: 2 |
(Interactive Brokers Client) I suddenly get the message "no security definition has been found for the request" Last Friday it still worked and yesterday i got the message. I use the data feed for GBL for a long time. Didn't change anything in the settings. How can I fix it? |
[2022-07-26 16:46:27] |
We have updated the Interactive Brokers EUREX Symbol Settings and changed -DTB to -EUREX due to a change from Interactive Brokers on July 24, 2022 Follow the instructions here to update the Symbol Settings within Sierra Chart: Global Symbol Settings: Update Global Symbol Settings You also need to update the -DTB to -EUREX for symbols in existing Charts, Trading DOMs and Quote Boards within Sierra Chart. Instructions: Changing the Symbol of a Chart The updated EUREX symbols are listed in File >> Find Symbol >> Futures-EUREX. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-26 16:46:57
